Kod za merac otkucaja srca
advancedgwt#5306
Postovi: 115
Post Postao/la advancedgwt#5306 » sub kol 18, 2018 3:22 pm
Gledao sam malo na YouTube ali nisam mogao da nadjem kod za merenje otkucaja srca sa jednostavnog senzora, bio je na popustu.
Svaka sugestija je dobrodosla.
david.zovko#9477
Postovi: 304
Re: Kod za merac otkucaja srca
Post Postao/la david.zovko#9477 » pon kol 20, 2018 12:28 pm
taj senzor nije baš najbolji za ovu primjenu, ali ako dobro i mirno držiš prst, dat će dobra očitanja. S jedne strane staviti fotodiodu, s druge strane diodu. Možeš koristiti ovaj kod:
int ledPin=13;
int sensorPin=0;
double alpha=0.75;
int period=20;
double change=0.0;
pinMode(ledPin,OUTPUT);
static double oldValue=0;
static double oldChange=0;
int rawValue=analogRead(sensorPin);
double value=alpha*oldValue+(1-alpha)*rawValue;
change=value-oldValue;
digitalWrite(ledPin,(change0.0));
oldValue=value;
oldChange=change;
delay(period);
advancedgwt#5306
Postovi: 115
Post Postao/la advancedgwt#5306 » pet ruj 14, 2018 2:46 pm
advancedgwt#5306
Postovi: 115
Post Postao/la advancedgwt#5306 » čet lis 25, 2018 8:44 pm
Davide,
Kad uradim verify u Arduino IDE dobijem ovu poruku
exit status 1
'change0' was not declared in this scope
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Takodje, ne mogu da vidim za senzoru sta je gnd, sta je + a sta je pin . Znam da je jednostavan senzor ali moze mnogo da zainteresuje i klince i starije
david.zovko#9477
Postovi: 304
Post Postao/la david.zovko#9477 » uto stu 06, 2018 12:59 pm
Oprosti, moja greška. Evo ispravnog koda:
int ledPin = 13;
int sensorPin = 0;
double alpha = 0.75;
int period = 20;
double change = 0.0;
  pinMode(ledPin, OUTPUT);
  static double oldValue = 0;
  static double oldChange = 0;
  int rawValue = analogRead(sensorPin);
  double value = alpha * oldValue + (1 - alpha) * rawValue;
  change = value - oldValue;
  digitalWrite(ledPin, (int)change);
  oldValue = value;
  oldChange = change;
  delay(period);
S prednje strane oznake imaš mali minus koji označava gnd, u sredini je +(kojega spojiš na pin 13 u ovom kodu), a na suprotnoj strani je senzor(kojega spajaš na pin A0 za ovaj kod) označen slovom S.
advancedgwt#5306
Postovi: 115
Post Postao/la advancedgwt#5306 » uto stu 06, 2018 2:46 pm
advancedgwt#5306
Postovi: 115
Post Postao/la advancedgwt#5306 » uto stu 06, 2018 2:57 pm
Davide,
Jer ledica na senzoru treba da svetli?
Takodje, gde ocitavam broj otkucaja srca? Ne vidim da je serial monitor ukljucen
david.zovko#9477
Postovi: 304
Post Postao/la david.zovko#9477 » pet stu 16, 2018 9:28 am
Ne, to je IR LEDica, tako da ljudsko oko ne može vidjeti tu svjetlost.
Da, oprosti, zaboravio sam taj dio. Znat ćeš ga uključiti i sam s Serial.begin(9600);, a varijable koje trebaš čitati su value(trenutna vrijednost) i change(promjena od zadnje vrijednosti)
advancedgwt#5306
Postovi: 115
Post Postao/la advancedgwt#5306 » pet stu 16, 2018 6:16 pm
advancedgwt#5306
Postovi: 115
Post Postao/la advancedgwt#5306 » pet stu 16, 2018 10:15 pm
Davide,
Evo koda i sada ocitava u serial monitoru ali pokazuje mi vrednost oko 300 bez obzira da li stavim prst izmedju LEDice i senzora.
Kada se gleda ravno na senzor, stavio san da je - sa desne strane, + u sredini a izlaz na levoj strani. Jer to tacan raspored?
int ledPin = 13;
int sensorPin = 0;
int period = 2000;
Serial.begin(9600); // For Serial Monitor
oldValue = value;
oldChange = change;
Serial.println (value);
Serial.println(change);
delay(period);
