Damba i Servo.h biblioteka
domagoj#8115
Postovi: 61
Post Postao/la domagoj#8115 » ned svi 12, 2019 8:24 pm
Dobivam compile grešku za Dambu kada uključim Servo.h datoteku. Naravno, kod Basic2 nema problema. Postoji li način da se Servo.h koristi s Dambom ili neka druga biblioteka?
Još program nisam ni počeo pisati, samo sam uključio biblioteku:
#include <Servo.h>
U nastavku je tekst greške.
Arduino: 1.8.5 (Windows 7), Board: "ATtiny25/45/85, ATtiny85, Internal 8 MHz"
D:\Program Files (x86)\arduino-1.8.5\libraries\Servo\src\avr\Servo.cpp: In function 'void __vector_3()':
D:\Program Files (x86)\arduino-1.8.5\libraries\Servo\src\avr\Servo.cpp:82:44: error: cannot convert 'volatile uint8_t* {aka volatile unsigned char*}' to 'volatile uint16_t* {aka volatile unsigned int*}' for argument '2' to 'void handle_interrupts(timer16_Sequence_t, volatile uint16_t*, volatile uint16_t*)'
   handle_interrupts(_timer1, &TCNT1, &OCR1A);
D:\Program Files (x86)\arduino-1.8.5\libraries\Servo\src\avr\Servo.cpp: In function 'void initISR(timer16_Sequence_t)':
D:\Program Files (x86)\arduino-1.8.5\libraries\Servo\src\avr\Servo.cpp:129:5: error: 'TCCR1B' was not declared in this scope
     TCCR1B = _BV(CS11);     // set prescaler of 8
D:\Program Files (x86)\arduino-1.8.5\libraries\Servo\src\avr\Servo.cpp:136:5: error: 'TIFR1' was not declared in this scope
     TIFR1 |= _BV(OCF1A);     // clear any pending interrupts;
D:\Program Files (x86)\arduino-1.8.5\libraries\Servo\src\avr\Servo.cpp:137:5: error: 'TIMSK1' was not declared in this scope
     TIMSK1 |=  _BV(OCIE1A) ; // enable the output compare interrupt
exit status 1
Error compiling for board ATtiny25/45/85.
david.zovko#6431
Postovi: 206
Re: Damba i Servo.h biblioteka
Post Postao/la david.zovko#6431 » ned svi 12, 2019 11:11 pm
Bok Domagoj!
Nismo još nikada probali tu kombinaciju, sad nemam blizu Attiny85, ali kako bi što brže dao odgovor; na netu javljaju da uspješno radi kombinacija librarya SoftwareServo i Attiny85: https://playground.arduino.cc/ComponentLib/Servo/
Example:
#include <SoftwareServo.h>
SoftwareServo servo;
  servo.attach(0);}
    int pos;
    for(pos = 0; pos < 180; pos += 1) {
        servo.write(pos);
        delay(50);
        SoftwareServo::refresh();
    for(pos = 180; pos>=1; pos-=1) {
        servo.write(pos);
        delay(50);
Molim te javi kada probaš! :)
domagoj#8115
Postovi: 61
Post Postao/la domagoj#8115 » pon svi 13, 2019 10:18 am
Hvala Davide!
Svakako javim.
domagoj#8115
Postovi: 61
Post Postao/la domagoj#8115 » pon svi 13, 2019 10:38 pm
Viva Damba!
Ona biblioteka koju je David naveo u gornjem postu radi, ali sam morao napraviti malu preinaku. Kada sam je uključio onakva kakva je javljala se compile greška da ne može naći WProgram.h datoteku. Onda sam malo googlao i našao da se u nekim situacijama (nisam istraživao koje) uzima ili WProgram.h ili Arduino.h datoteka. Editirao sam SoftwareServo.h i WProgram.h stavio u komentar a dodao Arduino.h. Evo koda:
#ifndef SoftwareServo_h
#define SoftwareServo_h
//#include <WProgram.h> //ovo isključiti
#include <Arduino.h> //ovo sam dodao
//dalje ništa ne treba dirati
#include <inttypes.h>
class SoftwareServo
  private:
    uint8_t pin;
    uint8_t angle;       // in degrees
    uint16_t pulse0;     // pulse width in TCNT0 counts
    uint8_t min16;       // minimum pulse, 16uS units  (default is 34)
    uint8_t max16;       // maximum pulse, 16uS units, 0-4ms range (default is 150)
    class SoftwareServo *next;
    static SoftwareServo* first;
  public:
    SoftwareServo();
    uint8_t attach(int);     // attach to a pin, sets pinMode, returns 0 on failure, won't
                             // position the servo until a subsequent write() happens
    void detach();
    void write(int);         // specify the angle in degrees, 0 to 180
    uint8_t read();
    uint8_t attached();
    void setMinimumPulse(uint16_t);  // pulse length for 0 degrees in microseconds, 540uS default
    void setMaximumPulse(uint16_t);  // pulse length for 180 degrees in microseconds, 2400uS default
    static void refresh();    // must be called at least every 50ms or so to keep servo alive
                              // you can call more often, it won't happen more than once every 20ms
Nakon toga compile je prošao bez greške. E, sad kako svoje Damba programe uglavnom testiram na Basic2 jer koristim blagodati serial monitora, onda volim koristiti #ifdef naredbe kako bi već kod compiliranja odredio ide li progam na Dambu ili Basic2. I tu mi se dogodila jedna compile greška koju nisam do sada sreo, a bila je ta da compiler nije prepoznavao osnovne naredbe, npr. digitalRead, analogRead itd. i to samo kada Damba nije bila definirana s #define naredbom, odnosno kada bi program copilirao za Basic2. Za Dambu je radilo bez greške. Budući da nije prepoznavao osnovne naredbe, dodao sam #include <Arduino.h> i sve je prošlo. Ne mogu objasniti u čemu je kvaka, ali ovako radi. Zanimljivo, kada program ne bi imao #ifdef naredbe, odnosno kada bi bio samo za Basic2, onda ne treba dodavati Arduino.h.
A sad ukratko koja je uloga programa. Pomoću malog servo motora mislim kontrolirati gas na trimeru za košenje trave. Trimer ima mehančku blokadu gasa ali tada je prejak, a osim toga, ovako ga mogu fino podešavati bez da rekonstruiram trimer. Trimer je leđne izvedbe, tj. motor je na leđima, a ručka i glava su preko pužnog mehanizma spojeni s motorom. Kako imam dosta strmog terena, ovo je super rješenje jer ručka s glavom nema neku težinu. Negativna strana je što nema ni balansa. Naime, standardni trimeri koriste motor kao protuuteg, a ovdje je motor na leđima, pa kada dodam gas, onda je okretni moment tako jak da baca u stranu. I kada se još uzme u obzir da se radi o strmini po kojoj teško i samo hodati, a kamoli i kositi, onda je držanje gasa konstantnim prava umjetnost. Nadam se da bi ovo rješenje moglo pomoći. Dakle, u igri su još jedno tipkalo i jedan potenciometar. Pritiskom na tipklao servo sluša potenciometar i mogu ga podesiti na željenu vrijednost. Ponovo stiskanje tipkala vraća servo u nulu i tako u krug. U stvari biram između ler gasa i gasa po volji a da pri tome ne moram držati ručicu gasa jer zbog strmine optimalan položaj ruku nije uvije isti.
Evo i programa:
#define Damba
#ifdef Damba
  SoftwareServo GasServo;
  #define prekidac 0
#else
  #include <Servo.h>
  Servo GasServo;
  #define prekidac 2
#define potPin A1
int potVal;
int kut;
bool servo_aktivan,prekidac_stanje;
bool PN_Edge(bool, bool);
pinMode(prekidac,INPUT);
prekidac_stanje=digitalRead(prekidac); //početno stanje digitalnog ulaza
#ifdef Damba
  GasServo.attach(1);
#else
  GasServo.attach(13);
} //end setup
  prekidac_stanje=PN_Edge(digitalRead(prekidac),prekidac_stanje); //pročitaj stanje digitalnog ulaza
  potVal = analogRead(potPin);
  kut = map(potVal, 0, 1023, 0, 179);
  if(servo_aktivan)
    kut=map(potVal, 0, 1023, 0, 179);
    kut=0;
  GasServo.write(kut);
  delay(15);
#ifdef Damba
#ifndef Damba
  Serial.print("Pot: ");
  Serial.print(potVal);
  Serial.print(", kut: ");
  Serial.println(kut);
} //end loop
bool PN_Edge(bool DI, bool DI_state) {
  //Iz LOW u HIGH
  if(DI!=DI_state && DI_state==LOW) {
    //ovdje dodaj kod za izvršenje P brida
    servo_aktivan=!servo_aktivan; //invertiraj stanje
    return HIGH;
  }//end if LOW u HIGH
  //Iz HIGH u LOW
    //ako ima više DI_state varijabli ovdje dodad if() pitallicu koja će razdjelidi DI variablu
    if(DI!=DI_state && DI_state==HIGH) {
    //ovdje dodaj kod za izvršenje N brida
    return LOW;
  }//end if HIGH u LOW
return DI_state; //vrati nepromijenjeno zadnje stanje
}//end PN_Edge
Prva faza je gotova, program radi upravo ono što treba. Sad još da to montiram na trimer, poslikam i javim imal li kakve koristi od toga.
LP, Domagoj
dekip#7988
Postovi: 44
Post Postao/la dekip#7988 » uto svi 14, 2019 8:38 am
Motorni trimer za travu? E živo me interesuje šta si smislio. :)
Mada verujem da je i kod vas vreme idealno za košenje trave. :D
david.zovko#6431
Postovi: 206
Post Postao/la david.zovko#6431 » sri svi 15, 2019 9:48 am
Ha, jako fora! Praktične primjene su mi najdraže :)
Ali da, kao što kaže Dejan, mislimo da nećeš još jedno vrijeme moći testirati :lol:
