Damba i Servo.h biblioteka
domagoj#1603
Post Postao/la domagoj#1603 » ned svi 12, 2019 8:24 pm
Dobivam compile grešku za Dambu kada uključim Servo.h datoteku. Naravno, kod Basic2 nema problema. Postoji li način da se Servo.h koristi s Dambom ili neka druga biblioteka?
Još program nisam ni počeo pisati, samo sam uključio biblioteku:
#include <Servo.h>
U nastavku je tekst greške.
Arduino: 1.8.5 (Windows 7), Board: "ATtiny25/45/85, ATtiny85, Internal 8 MHz"
D:\Program Files (x86)\arduino-1.8.5\libraries\Servo\src\avr\Servo.cpp: In function 'void __vector_3()':
D:\Program Files (x86)\arduino-1.8.5\libraries\Servo\src\avr\Servo.cpp:82:44: error: cannot convert 'volatile uint8_t* {aka volatile unsigned char*}' to 'volatile uint16_t* {aka volatile unsigned int*}' for argument '2' to 'void handle_interrupts(timer16_Sequence_t, volatile uint16_t*, volatile uint16_t*)'
   handle_interrupts(_timer1, &TCNT1, &OCR1A);
D:\Program Files (x86)\arduino-1.8.5\libraries\Servo\src\avr\Servo.cpp: In function 'void initISR(timer16_Sequence_t)':
D:\Program Files (x86)\arduino-1.8.5\libraries\Servo\src\avr\Servo.cpp:129:5: error: 'TCCR1B' was not declared in this scope
     TCCR1B = _BV(CS11);     // set prescaler of 8
D:\Program Files (x86)\arduino-1.8.5\libraries\Servo\src\avr\Servo.cpp:136:5: error: 'TIFR1' was not declared in this scope
     TIFR1 |= _BV(OCF1A);     // clear any pending interrupts;
D:\Program Files (x86)\arduino-1.8.5\libraries\Servo\src\avr\Servo.cpp:137:5: error: 'TIMSK1' was not declared in this scope
     TIMSK1 |=  _BV(OCIE1A) ; // enable the output compare interrupt
exit status 1
Error compiling for board ATtiny25/45/85.
david.zovko#9533
Postovi: 331
Re: Damba i Servo.h biblioteka
Post Postao/la david.zovko#9533 » ned svi 12, 2019 11:11 pm
Bok Domagoj!
Nismo još nikada probali tu kombinaciju, sad nemam blizu Attiny85, ali kako bi što brže dao odgovor; na netu javljaju da uspješno radi kombinacija librarya SoftwareServo i Attiny85: https://playground.arduino.cc/ComponentLib/Servo/
Example:
#include <SoftwareServo.h>
SoftwareServo servo;
  servo.attach(0);}
    int pos;
    for(pos = 0; pos < 180; pos += 1) {
        servo.write(pos);
        delay(50);
        SoftwareServo::refresh();
    for(pos = 180; pos>=1; pos-=1) {
        servo.write(pos);
        delay(50);
Molim te javi kada probaš! :)
domagoj#1603
Post Postao/la domagoj#1603 » pon svi 13, 2019 10:18 am
Hvala Davide!
Svakako javim.
domagoj#1603
Post Postao/la domagoj#1603 » pon svi 13, 2019 10:38 pm
Viva Damba!
Ona biblioteka koju je David naveo u gornjem postu radi, ali sam morao napraviti malu preinaku. Kada sam je uključio onakva kakva je javljala se compile greška da ne može naći WProgram.h datoteku. Onda sam malo googlao i našao da se u nekim situacijama (nisam istraživao koje) uzima ili WProgram.h ili Arduino.h datoteka. Editirao sam SoftwareServo.h i WProgram.h stavio u komentar a dodao Arduino.h. Evo koda:
#ifndef SoftwareServo_h
#define SoftwareServo_h
//#include <WProgram.h> //ovo isključiti
#include <Arduino.h> //ovo sam dodao
//dalje ništa ne treba dirati
#include <inttypes.h>
class SoftwareServo
  private:
    uint8_t pin;
    uint8_t angle;       // in degrees
    uint16_t pulse0;     // pulse width in TCNT0 counts
    uint8_t min16;       // minimum pulse, 16uS units  (default is 34)
    uint8_t max16;       // maximum pulse, 16uS units, 0-4ms range (default is 150)
    class SoftwareServo *next;
    static SoftwareServo* first;
  public:
    SoftwareServo();
    uint8_t attach(int);     // attach to a pin, sets pinMode, returns 0 on failure, won't
                             // position the servo until a subsequent write() happens
    void detach();
    void write(int);         // specify the angle in degrees, 0 to 180
    uint8_t read();
    uint8_t attached();
    void setMinimumPulse(uint16_t);  // pulse length for 0 degrees in microseconds, 540uS default
    void setMaximumPulse(uint16_t);  // pulse length for 180 degrees in microseconds, 2400uS default
    static void refresh();    // must be called at least every 50ms or so to keep servo alive
                              // you can call more often, it won't happen more than once every 20ms
#endif
Nakon toga compile je prošao bez greške. E, sad kako svoje Damba programe uglavnom testiram na Basic2 jer koristim blagodati serial monitora, onda volim koristiti #ifdef naredbe kako bi već kod compiliranja odredio ide li progam na Dambu ili Basic2. I tu mi se dogodila jedna compile greška koju nisam do sada sreo, a bila je ta da compiler nije prepoznavao osnovne naredbe, npr. digitalRead, analogRead itd. i to samo kada Damba nije bila definirana s #define naredbom, odnosno kada bi program copilirao za Basic2. Za Dambu je radilo bez greške. Budući da nije prepoznavao osnovne naredbe, dodao sam #include <Arduino.h> i sve je prošlo. Ne mogu objasniti u čemu je kvaka, ali ovako radi. Zanimljivo, kada program ne bi imao #ifdef naredbe, odnosno kada bi bio samo za Basic2, onda ne treba dodavati Arduino.h.
A sad ukratko koja je uloga programa. Pomoću malog servo motora mislim kontrolirati gas na trimeru za košenje trave. Trimer ima mehančku blokadu gasa ali tada je prejak, a osim toga, ovako ga mogu fino podešavati bez da rekonstruiram trimer. Trimer je leđne izvedbe, tj. motor je na leđima, a ručka i glava su preko pužnog mehanizma spojeni s motorom. Kako imam dosta strmog terena, ovo je super rješenje jer ručka s glavom nema neku težinu. Negativna strana je što nema ni balansa. Naime, standardni trimeri koriste motor kao protuuteg, a ovdje je motor na leđima, pa kada dodam gas, onda je okretni moment tako jak da baca u stranu. I kada se još uzme u obzir da se radi o strmini po kojoj teško i samo hodati, a kamoli i kositi, onda je držanje gasa konstantnim prava umjetnost. Nadam se da bi ovo rješenje moglo pomoći. Dakle, u igri su još jedno tipkalo i jedan potenciometar. Pritiskom na tipklao servo sluša potenciometar i mogu ga podesiti na željenu vrijednost. Ponovo stiskanje tipkala vraća servo u nulu i tako u krug. U stvari biram između ler gasa i gasa po volji a da pri tome ne moram držati ručicu gasa jer zbog strmine optimalan položaj ruku nije uvije isti.
Evo i programa:
#define Damba
#ifdef Damba
  SoftwareServo GasServo;
  #define prekidac 0
#else
  #include <Servo.h>
  Servo GasServo;
  #define prekidac 2
#endif
#define potPin A1
int potVal;
int kut;
bool servo_aktivan,prekidac_stanje;
bool PN_Edge(bool, bool);
pinMode(prekidac,INPUT);
prekidac_stanje=digitalRead(prekidac); //početno stanje digitalnog ulaza
#ifdef Damba
  GasServo.attach(1);
#else
  GasServo.attach(13);
#endif
} //end setup
  prekidac_stanje=PN_Edge(digitalRead(prekidac),prekidac_stanje); //pročitaj stanje digitalnog ulaza
  potVal = analogRead(potPin);
  kut = map(potVal, 0, 1023, 0, 179);
  if(servo_aktivan)
    kut=map(potVal, 0, 1023, 0, 179);
    kut=0;
  GasServo.write(kut);
  delay(15);
#ifdef Damba
#endif
#ifndef Damba
  Serial.print("Pot: ");
  Serial.print(potVal);
  Serial.print(", kut: ");
  Serial.println(kut);
#endif
} //end loop
bool PN_Edge(bool DI, bool DI_state) {
  //Iz LOW u HIGH
  if(DI!=DI_state && DI_state==LOW) {
    //ovdje dodaj kod za izvršenje P brida
    servo_aktivan=!servo_aktivan; //invertiraj stanje
    return HIGH;
  }//end if LOW u HIGH
  //Iz HIGH u LOW
    //ako ima više DI_state varijabli ovdje dodad if() pitallicu koja će razdjelidi DI variablu
    if(DI!=DI_state && DI_state==HIGH) {
    //ovdje dodaj kod za izvršenje N brida
    return LOW;
  }//end if HIGH u LOW
return DI_state; //vrati nepromijenjeno zadnje stanje
}//end PN_Edge
Prva faza je gotova, program radi upravo ono što treba. Sad još da to montiram na trimer, poslikam i javim imal li kakve koristi od toga.
LP, Domagoj
dekip#4656
Post Postao/la dekip#4656 » uto svi 14, 2019 8:38 am
Motorni trimer za travu? E živo me interesuje šta si smislio. :)
Mada verujem da je i kod vas vreme idealno za košenje trave. :D
david.zovko#9533
Postovi: 331
Post Postao/la david.zovko#9533 » sri svi 15, 2019 9:48 am
Ha, jako fora! Praktične primjene su mi najdraže :)
Ali da, kao što kaže Dejan, mislimo da nećeš još jedno vrijeme moći testirati :lol:
