Ne kompajlira kod za NOVA2
dd#3433
Pridružen/a: uto pro 17, 2019 1:05 pm
Post Postao/la dd#3433 » ned vel 02, 2020 7:20 pm
Instalirao sve prema tutorijalu.
Copy/Pejstao kod za LED13 prema istome
pinMode(13, OUTPUT);
digitalWrite(13, HIGH);
digitalWrite(13, LOW);
i pokrenuo kompajler.
Javlja error::
Arduino: 1.8.10 (Mac OS X 10.14.1), Board: "Generic ESP8266 Module, 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), dtr (aka nodemcu), 26 MHz, 40MHz, QIO (fast), 4MB (FS:1MB OTA:~1019KB), 13, nonos-sdk 2.2.1+100 (190703), v2 Lower Memory, Disabled, None, Only Sketch, 921600"
fork/exec /Users/davordelic/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1/python3: no such file or directory
Error compiling for board Generic ESP8266 Module.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
phyton3 fajl je na svom mjestu u folderu kako je gore navedeno..
json je instalirao tekuću verziju 2.6.3. (mislim) pa su se parametri neki gore pojavili koji nisu bili u tutorijalu. Pokušao sam downgrejdati na 2.4.2. ali mi više nema u Library Manageru esp8266 by ESP8266 Community, iako su u Toolsu na raspolaganju i dalje sve ESP8266 ploče. Nasumice birao druge da vidim hoće li biti koji drugi error, no uvijek vraća isto.
Prepoznaje ploču s porukom:
BN: Unknown board
VID: 1A86
PID: 7523
SN: Upload any sketch to obtain it
BASIC3 ploča radi cakum-pakum.
Dolje je verbosen error:
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/davordelic/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/davordelic/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/davordelic/Documents/Arduino/libraries -fqbn=esp8266:esp8266:generic:xtal=80,vt=flash,exception=legacy,ssl=all,ResetMethod=nodemcu,CrystalFreq=26,FlashFreq=40,FlashMode=qio,eesz=4M1M,led=13,sdk=nonosdk_190703,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=921600 -vid-pid=1A86_7523 -ide-version=10810 -build-path /var/folders/91/zywt0kc12674xv0bv17kchc00000gn/T/arduino_build_851194 -warnings=none -build-cache /var/folders/91/zywt0kc12674xv0bv17kchc00000gn/T/arduino_cache_598500 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=/Users/davordelic/Library/Arduino15/packages/esp8266/tools/mkspiffs/2.5.0-4-b40a506 -prefs=runtime.tools.mkspiffs-2.5.0-4-b40a506.path=/Users/davordelic/Library/Arduino15/packages/esp8266/tools/mkspiffs/2.5.0-4-b40a506 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=/Users/davordelic/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506 -prefs=runtime.tools.xtensa-lx106-elf-gcc-2.5.0-4-b40a506.path=/Users/davordelic/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506 -prefs=runtime.tools.mklittlefs.path=/Users/davordelic/Library/Arduino15/packages/esp8266/tools/mklittlefs/2.5.0-4-69bd9e6 -prefs=runtime.tools.mklittlefs-2.5.0-4-69bd9e6.path=/Users/davordelic/Library/Arduino15/packages/esp8266/tools/mklittlefs/2.5.0-4-69bd9e6 -prefs=runtime.tools.python3.path=/Users/davordelic/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=/Users/davordelic/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1 -verbose /Users/davordelic/Documents/Arduino/Nova2LED13test/Nova2LED13test.ino
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/davordelic/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/davordelic/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/davordelic/Documents/Arduino/libraries -fqbn=esp8266:esp8266:generic:xtal=80,vt=flash,exception=legacy,ssl=all,ResetMethod=nodemcu,CrystalFreq=26,FlashFreq=40,FlashMode=qio,eesz=4M1M,led=13,sdk=nonosdk_190703,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=921600 -vid-pid=1A86_7523 -ide-version=10810 -build-path /var/folders/91/zywt0kc12674xv0bv17kchc00000gn/T/arduino_build_851194 -warnings=none -build-cache /var/folders/91/zywt0kc12674xv0bv17kchc00000gn/T/arduino_cache_598500 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=/Users/davordelic/Library/Arduino15/packages/esp8266/tools/mkspiffs/2.5.0-4-b40a506 -prefs=runtime.tools.mkspiffs-2.5.0-4-b40a506.path=/Users/davordelic/Library/Arduino15/packages/esp8266/tools/mkspiffs/2.5.0-4-b40a506 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=/Users/davordelic/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506 -prefs=runtime.tools.xtensa-lx106-elf-gcc-2.5.0-4-b40a506.path=/Users/davordelic/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506 -prefs=runtime.tools.mklittlefs.path=/Users/davordelic/Library/Arduino15/packages/esp8266/tools/mklittlefs/2.5.0-4-69bd9e6 -prefs=runtime.tools.mklittlefs-2.5.0-4-69bd9e6.path=/Users/davordelic/Library/Arduino15/packages/esp8266/tools/mklittlefs/2.5.0-4-69bd9e6 -prefs=runtime.tools.python3.path=/Users/davordelic/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=/Users/davordelic/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1 -verbose /Users/davordelic/Documents/Arduino/Nova2LED13test/Nova2LED13test.ino
Using board 'generic' from platform in folder: /Users/davordelic/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3
Using core 'esp8266' from platform in folder: /Users/davordelic/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3
Detecting libraries used...
/Users/davordelic/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/Users/davordelic/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/sdk/include -I/Users/davordelic/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/sdk/lwip2/include -I/Users/davordelic/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/91/zywt0kc12674xv0bv17kchc00000gn/T/arduino_build_851194/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10810 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=13 -DFLASHMODE_QIO -DESP8266 -I/Users/davordelic/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/cores/esp8266 -I/Users/davordelic/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/variants/generic /var/folders/91/zywt0kc12674xv0bv17kchc00000gn/T/arduino_build_851194/sketch/Nova2LED13test.ino.cpp -o /dev/null
Generating function prototypes...
/Users/davordelic/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/Users/davordelic/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/sdk/include -I/Users/davordelic/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/sdk/lwip2/include -I/Users/davordelic/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/91/zywt0kc12674xv0bv17kchc00000gn/T/arduino_build_851194/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10810 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=13 -DFLASHMODE_QIO -DESP8266 -I/Users/davordelic/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/cores/esp8266 -I/Users/davordelic/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/variants/generic /var/folders/91/zywt0kc12674xv0bv17kchc00000gn/T/arduino_build_851194/sketch/Nova2LED13test.ino.cpp -o /var/folders/91/zywt0kc12674xv0bv17kchc00000gn/T/arduino_build_851194/preproc/ctags_target_for_gcc_minus_e.cpp
/Applications/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /var/folders/91/zywt0kc12674xv0bv17kchc00000gn/T/arduino_build_851194/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/Users/davordelic/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1/python3 /Users/davordelic/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/signing.py --mode header --publickey /Users/davordelic/Documents/Arduino/Nova2LED13test/public.key --out /var/folders/91/zywt0kc12674xv0bv17kchc00000gn/T/arduino_build_851194/core/Updater_Signing.h
domagoj#8651
Postovi: 147
Re: Ne kompajlira kod za NOVA2
Post Postao/la domagoj#8651 » ned vel 02, 2020 7:46 pm
Ne kužim se toliko da bi mogao analizrati ovaj verbosen error, ali u nastavku su postavke koje kod mene rade.
U tools meniu je ovako postavljeno:
- Flash Mode: DIO
- Flash size: 4M (1M SPIFFS)
- Reset method: nodemcu
- Flash Frequency: 40MHz
- Upload using Serial
- CPU Frequency: 80MHz
- Upload Speed: 115200
david.zovko#2123
Post Postao/la david.zovko#2123 » čet vel 06, 2020 3:18 pm
Budući da ne uspijevate compile-ati, mora biti greška negdje u postavkama. Možete li staviti screenshot Tools izbornika iz Arduino IDE?
Možda nije ni na odmet reinstallirati esp8266 definiciju, možda nešto nije prošlo dobro. Dakle, stavite link opet u perferences -> additional boards URLs, pa iz board managera prvo "remove" pa "install" najnoviju verziju.
dd#3433
Post Postao/la dd#3433 » pet vel 07, 2020 10:49 am
Sve to probah ... A kada sam isao deinstalirati library vise ga nije bilo..Đe nestade? A ploče sve i dalje u Library Manageru ...
dd#3433
Post Postao/la dd#3433 » pet vel 07, 2020 2:39 pm
david.zovko#2123
Post Postao/la david.zovko#2123 » sub vel 08, 2020 1:56 pm
Tools izbornik izgleda OK.
Na Board Manageru možda pokušajte upisati samo "esp8266", ni meni ne pronađe kada upišem cijeli tekst kao kod Vas.
Možete li možda pokušati na drugom računalu; ovdje izgleda kao da je problem s nečime dubljim, pa da pokušamo izbjeći da ulazimo u taj dio.
dd#3433
Post Postao/la dd#3433 » pon vel 10, 2020 3:59 pm
Ne nalazi ni kad utipkam kraći string ...
Nebitno ... i ja mislim da je nesto s racunalom poslo krivo negdi, no nemam drugog pa cu reinstalirati Arduino i sve iz nova pa da vidimo ...
Javim result
Thnx
D.
david.zovko#2123
Post Postao/la david.zovko#2123 » pon vel 10, 2020 7:56 pm
To će nam biti najlakše, pa molim Vas javite kada probate na drugom računalu!
