Problem sa OLED kodom
Tehnička podrška za sve module i aktuatore iz ponude e-radionica.com
advancedgwt#8018
Postovi: 118
Post Postao/la advancedgwt#8018 » uto lis 22, 2019 12:52 pm
Sastavio sam prema KKM OLED i kad hocu da kompajliram dobijem sledecu gresku
Arduino: 1.8.5 (Windows 10), Board: "Arduino Nano, ATmega328P"
OLED1:20: error: could not convert 'display.Adafruit_SSD1306::begin(2u, 60u, true)' from 'void' to 'bool'
 if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Adresa 0x3C za 128x32 displej
OLED1:20: error: in argument to unary !
Using library Wire at version 1.0 in folder: C:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.207\libraries\Wire
Using library Adafruit_SSD1306-master at version 1.1.2 in folder: C:\Users\dkaludjerovic\Documents\Arduino\libraries\Adafruit_SSD1306-master
Using library SPI at version 1.0 in folder: C:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.207\libraries\SPI
Using library Adafruit-GFX-Library-master at version 1.2.9 in folder: C:\Users\dkaludjerovic\Documents\Arduino\libraries\Adafruit-GFX-Library-master
Using library DHT-sensor-library-master at version 1.3.7 in folder: C:\Users\dkaludjerovic\Documents\Arduino\libraries\DHT-sensor-library-master
Using library Adafruit_Sensor-master at version 1.0.2 in folder: C:\Users\dkaludjerovic\Documents\Arduino\libraries\Adafruit_Sensor-master
exit status 1
david.zovko#9779
Postovi: 344
Re: Problem sa OLED kodom
Post Postao/la david.zovko#9779 » sri lis 23, 2019 8:25 am
radi se o OLED 128x32?
Ovaj KKM: https://e-radionica.com/hr/blog/2019/09 ... ed-128x32/ ?
advancedgwt#8018
Postovi: 118
Post Postao/la advancedgwt#8018 » sri lis 23, 2019 6:50 pm
Da, taj mi je stigao pre par dana
david.zovko#9779
Postovi: 344
Post Postao/la david.zovko#9779 » čet lis 24, 2019 8:35 am
Dragane
molim te provjeri, nanovo restartiraj računalo i otvori novi kod u Arduino IDE, meni se oba primjera iz KKM-a uredno compileaju i uploadaju.
advancedgwt#8018
Postovi: 118
Post Postao/la advancedgwt#8018 » pet lis 25, 2019 11:43 am
Probacu, simpatican je taj mali OLED.
advancedgwt#8018
Postovi: 118
Post Postao/la advancedgwt#8018 » pet lis 25, 2019 1:33 pm
Opet isto, ova linija je problem
david.zovko#9779
Postovi: 344
Post Postao/la david.zovko#9779 » pon lis 28, 2019 9:27 am
Molim te screenshot Tools izbornika iz Arduino IDE (Gdje se vidi koja je ploča odabrana i ostale opcije)
A također, c/p cijele greške koju dobivaš. Ako si nešto mijenjao u kodu, molim te i kod
advancedgwt#8018
Postovi: 118
Post Postao/la advancedgwt#8018 » pon lis 28, 2019 6:23 pm
Evo prvo ovo
advancedgwt#8018
Postovi: 118
Post Postao/la advancedgwt#8018 » pon lis 28, 2019 6:24 pm
Nisam nista menjao u kodu.
david.zovko#9779
Postovi: 344
Post Postao/la david.zovko#9779 » sri lis 30, 2019 2:31 pm
Processor ti mora biti "Atmega328P (Old Bootloader)"
Port ćeš odabrati kada spojiš pločicu
Jel radi tako?
advancedgwt#8018
Postovi: 118
Post Postao/la advancedgwt#8018 » čet lis 31, 2019 11:22 am
Ne tako je bilo od pocetka
advancedgwt#8018
Postovi: 118
Post Postao/la advancedgwt#8018 » sub stu 02, 2019 3:17 pm
Sad sam proverio, u Arduino IDE uopste nemam opciju za old bootloader
advancedgwt#8018
Postovi: 118
Post Postao/la advancedgwt#8018 » pon stu 04, 2019 8:45 pm
Instalirao sam sve na drugom kompjuteru i dobio ovo
advancedgwt#7982 je napisao/la:
advancedgwt#8018
Postovi: 118
Post Postao/la advancedgwt#8018 » sub stu 09, 2019 10:38 pm
Resio sam ovaj problem iz prethodne poruke ali opet mi se javlja ista greska i na drugom kompjuteru.
Da li imate negde I2C scanner?
domagoj#5559
Postovi: 199
Post Postao/la domagoj#5559 » sub stu 09, 2019 10:41 pm
Evo ga.
 * I2CScanner.ino -- I2C bus scanner for Arduino
 * 2009,2014, Tod E. Kurt, http://todbot.com/blog/
#include "Wire.h"
extern "C" {
#include "utility/twi.h"  // from Wire library, so we can do bus scanning
// Scan the I2C bus between addresses from_addr and to_addr.
// On each address, call the callback function with the address and result.
// If result==0, address was found, otherwise, address wasn't found
// (can use result to potentially get other status on the I2C bus, see twi.c)
// Assumes Wire.begin() has already been called
void scanI2CBus(byte from_addr, byte to_addr,
                void(*callback)(byte address, byte result) )
  byte rc;
  byte data = 0; // not used, just an address to feed to twi_writeTo()
  for( byte addr = from_addr; addr <= to_addr; addr++ ) {
    rc = twi_writeTo(addr, &data, 0, 1, 0);
    callback( addr, rc );
// Called when address is found in scanI2CBus()
// Feel free to change this as needed
// (like adding I2C comm code to figure out what kind of I2C device is there)
void scanFunc( byte addr, byte result ) {
  Serial.print("addr: ");
  Serial.print(addr,DEC);
  Serial.print( (result==0) ? " found!":"       ");
  Serial.print( (addr%4) ? "\t":"\n");
byte start_address = 8;       // lower addresses are reserved to prevent conflicts with other protocols
byte end_address = 119;       // higher addresses unlock other modes, like 10-bit addressing
// standard Arduino setup()
void setup()
    Wire.begin();
    Serial.begin(9600);                   // Changed from 19200 to 9600 which seems to be default for Arduino serial monitor
    Serial.println("\nI2CScanner ready!");
    Serial.print("starting scanning of I2C bus from ");
    Serial.print(start_address,DEC);
    Serial.print(" to ");
    Serial.print(end_address,DEC);
    Serial.println("...");
    // start the scan, will call "scanFunc()" on result from each address
    scanI2CBus( start_address, end_address, scanFunc );
    Serial.println("\ndone");
    // Set pin mode so the loop code works ( Not required for the functionality)
    pinMode(13, OUTPUT);
// standard Arduino loop()
    // Nothing to do here, so we'll just blink the built-in LED
    digitalWrite(13,HIGH);
    delay(300);
    digitalWrite(13,LOW);
    delay(300);
