Da li Croduino BASIC 3 moze da cite SDI 12 izlaz sa senzora?
advancedgwt#6600
Postovi: 119
Pridružen/a: pon lip 11, 2018 12:42 pm
Post Postao/la advancedgwt#6600 » uto ožu 12, 2019 3:53 pm
A ukoliko ne moze da li ima neki adapter? To bi bilo bas zgodno.
Srdacno,
haluzanpavao#7409
Postovi: 26
Re: Da li Croduino BASIC 3 moze da cite SDI 12 izlaz sa senzora?
Post Postao/la haluzanpavao#7409 » uto ožu 12, 2019 6:25 pm
Isprobaj ovaj skeć
#        OVERVIEW      #
 Example D: Checks all addresses for active sensors, and logs data for each sensor every minute.
 This is a simple demonstration of the SDI-12 library for Arduino.
 It discovers the address of all sensors active on a single bus and takes measurements from them.
 Every SDI-12 device is different in the time it takes to take a measurement, and the amount of data it returns.
 This sketch will not serve every sensor type, but it will likely be helpful in getting you started.
 Each sensor should have a unique address already - if not, multiple sensors may respond simultaenously
 to the same request and the output will not be readable by the Arduino.
 To address a sensor, please see Example B: b_address_change.ino
#      THE CIRCUIT      #
 You  may use one or more pre-adressed sensors.
 See:
 https://raw.github.com/Kevin-M-Smith/SDI-12-Circuit-Diagrams/master/basic_setup_usb_multiple_sensors.png
 or
 https://raw.github.com/Kevin-M-Smith/SDI-12-Circuit-Diagrams/master/compat_setup_usb_multiple_sensors.png
 or
 https://raw.github.com/Kevin-M-Smith/SDI-12-Circuit-Diagrams/master/basic_setup_usb.png
 or
 https://raw.github.com/Kevin-M-Smith/SDI-12-Circuit-Diagrams/master/compat_setup_usb.png
#      COMPATIBILITY      #
 This library requires the use of pin change interrupts (PCINT).
 Not all Arduino boards have the same pin capabilities.
 The known compatibile pins for common variants are shown below.
 Arduino Uno:   All pins.
 Arduino Mega or Mega 2560:
 10, 11, 12, 13, 14, 15, 50, 51, 52, 53, A8 (62),
 A9 (63), A10 (64), A11 (65), A12 (66), A13 (67), A14 (68), A15 (69).
 Arduino Leonardo:
 8, 9, 10, 11, 14 (MISO), 15 (SCK), 16 (MOSI)
#      RESOURCES        #
 Written by Kevin M. Smith in 2013.
 Contact: SDI12@ethosengineering.org
 The SDI-12 specification is available at: http://www.sdi-12.org/
 The library is available at: https://github.com/StroudCenter/Arduino-SDI-12
#include <SDI12.h>
#define DATAPIN 2         // change to the proper pin
SDI12 mySDI12(DATAPIN);
// keeps track of active addresses
// each bit represents an address:
// 1 is active (taken), 0 is inactive (available)
// setTaken('A') will set the proper bit for sensor 'A'
// set
byte addressRegister[8] = {
  0B00000000,
  0B00000000,
  0B00000000,
  0B00000000,
  0B00000000,
  0B00000000,
  0B00000000,
  0B00000000
void setup(){
  Serial.begin(57600);
  mySDI12.begin();
  delay(500); // allow things to settle
  Serial.println("Scanning all addresses, please wait...");
      Quickly Scan the Address Space
  for(byte i = '0'; i <= '9'; i++) if(checkActive(i)) setTaken(i);   // scan address space 0-9
  for(byte i = 'a'; i <= 'z'; i++) if(checkActive(i)) setTaken(i);   // scan address space a-z
  for(byte i = 'A'; i <= 'Z'; i++) if(checkActive(i)) setTaken(i);   // scan address space A-Z
      See if there are any active sensors.
  boolean found = false;
  for(byte i = 0; i < 62; i++){
    if(isTaken(i)){
      found = true;
      break;
  if(!found) {
    Serial.println("No sensors found, please check connections and restart the Arduino.");
    while(true);
  } // stop here
  Serial.println();
  Serial.println("Time Elapsed (s), Sensor Address and ID, Measurement 1, Measurement 2, ... etc.");
  Serial.println("-------------------------------------------------------------------------------");
void loop(){
  for(char i = '0'; i <= '9'; i++) if(isTaken(i)){
    Serial.print(millis()/1000);
    Serial.print(",");
    printInfo(i);
    takeMeasurement(i);
  for(char i = 'a'; i <= 'z'; i++) if(isTaken(i)){
    Serial.print(",");
    printInfo(i);
    takeMeasurement(i);
  for(char i = 'A'; i <= 'Z'; i++) if(isTaken(i)){
    Serial.print(",");
    printInfo(i);
    takeMeasurement(i);
  delay(10000); // wait ten seconds between measurement attempts.
void takeMeasurement(char i){
  String command = "";
  command += i;
  command += "M!"; // SDI-12 measurement command format  [address]['M'][!]
  mySDI12.sendCommand(command);
  while(!mySDI12.available()>5); // wait for acknowlegement with format [address][ttt (3 char, seconds)][number of measurments available, 0-9]
  delay(100);
  mySDI12.read(); //consume address
  // find out how long we have to wait (in seconds).
  int wait = 0;
  wait += 100 * mySDI12.read()-'0';
  wait += 10 * mySDI12.read()-'0';
  wait += 1 * mySDI12.read()-'0';
  mySDI12.read(); // ignore # measurements, for this simple examlpe
  mySDI12.read(); // ignore carriage return
  mySDI12.read(); // ignore line feed
  long timerStart = millis();
  while((millis() - timerStart) > (1000 * wait)){
    if(mySDI12.available()) break;                //sensor can interrupt us to let us know it is done early
  // in this example we will only take the 'DO' measurement
  mySDI12.flush();
  command = "";
  command += i;
  command += "D0!"; // SDI-12 command to get data [address][D][dataOption][!]
  while(!mySDI12.available()>1); // wait for acknowlegement
  delay(300); // let the data transfer
  printBufferToScreen();
  mySDI12.flush();
void printBufferToScreen(){
  String buffer = "";
  mySDI12.read(); // consume address
  while(mySDI12.available()){
    char c = mySDI12.read();
    if(c == '+' || c == '-'){
      buffer += ',';
      if(c == '-') buffer += '-';
    else {
      buffer += c;
    delay(100);
 Serial.print(buffer);
// this checks for activity at a particular address
// expects a char, '0'-'9', 'a'-'z', or 'A'-'Z'
boolean checkActive(char i){
  String myCommand = "";
  myCommand = "";
  myCommand += (char) i;                 // sends basic 'acknowledge' command [address][!]
  myCommand += "!";
  for(int j = 0; j < 3; j++){            // goes through three rapid contact attempts
    mySDI12.sendCommand(myCommand);
    if(mySDI12.available()>1) break;
    delay(30);
  if(mySDI12.available()>2){       // if it hears anything it assumes the address is occupied
    mySDI12.flush();
    return true;
  else {   // otherwise it is vacant.
    mySDI12.flush();
  return false;
// this sets the bit in the proper location within the addressRegister
// to record that the sensor is active and the address is taken.
boolean setTaken(byte i){
  boolean initStatus = isTaken(i);
  i = charToDec(i); // e.g. convert '0' to 0, 'a' to 10, 'Z' to 61.
  byte j = i / 8;   // byte #
  byte k = i % 8;   // bit #
  addressRegister[j] |= (1 << k);
  return !initStatus; // return false if already taken
// THIS METHOD IS UNUSED IN THIS EXAMPLE, BUT IT MAY BE HELPFUL.
// this unsets the bit in the proper location within the addressRegister
boolean setVacant(byte i){
  addressRegister[j] &= ~(1 << k);
  return initStatus; // return false if already vacant
// this quickly checks if the address has already been taken by an active sensor
boolean isTaken(byte i){
  return addressRegister[j] & (1<<k); // return bit status
// gets identification information from a sensor, and prints it to the serial port
// expects a character between '0'-'9', 'a'-'z', or 'A'-'Z'.
char printInfo(char i){
  int j;
  command += (char) i;
  command += "I!";
  for(j = 0; j < 1; j++){
    delay(30);
    if(mySDI12.available()) mySDI12.read();
    if((c!='\n') && (c!='\r')) Serial.write(c);
    delay(5);
// converts allowable address characters '0'-'9', 'a'-'z', 'A'-'Z',
// to a decimal number between 0 and 61 (inclusive) to cover the 62 possible addresses
byte charToDec(char i){
  if((i >= '0') && (i <= '9')) return i - '0';
  if((i >= 'a') && (i <= 'z')) return i - 'a' + 10;
  if((i >= 'A') && (i <= 'Z')) return i - 'A' + 37;
// maps a decimal number between 0 and 61 (inclusive) to
// allowable address characters '0'-'9', 'a'-'z', 'A'-'Z',
char decToChar(byte i){
  if((i >= 0) && (i <= 9)) return i + '0';
  if((i >= 10) && (i <= 36)) return i + 'a' - 10;
  if((i >= 37) && (i <= 62)) return i + 'A' - 37;
advancedgwt#6600
Postovi: 119
Post Postao/la advancedgwt#6600 » uto ožu 12, 2019 9:35 pm
Hocu hvala
