digitalWrite() i delay u voidu od interrupta ne radi
karlo.schweiger#8434
Pridružen/a: sri tra 07, 2021 11:31 am
Post Postao/la karlo.schweiger#8434 » sri tra 07, 2021 11:39 am
Pozdrav, problem je taj da kada se vrti void od interrupta digitalWrite ne radi i delay kao da nema svrhu
volatile int pwm_value = 0;
volatile int prev_time = 0;
volatile int pwm_value2 = 0;
volatile int prev_time2 = 0;
const byte ledPin = 13;
const byte interruptPin = 3;
const byte interruptPin2 = 2;
int sendPin = 12; // pin koji šalje pulseve dalje u aparat
int FiskalPulseSendCoin = 5; //Pin koji salje pulseve zetonjere na fiskalizaciju - 1kn = 1puls,20ms...
int FiskalPulseSendNote = 7; //Pin koji salje pulseve akceptora na fiskalizaciju - 10kn = 1puls,50ms...
Serial.begin(115200);
pinMode(ledPin, OUTPUT);
pinMode(interruptPin, INPUT_PULLUP);
pinMode(interruptPin2, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(interruptPin), FiskNov, FALLING);
attachInterrupt(digitalPinToInterrupt(interruptPin2), FiskCoin, FALLING);
digitalWrite(interruptPin2, HIGH);
pinMode(sendPin, OUTPUT);
pinMode(FiskalPulseSendCoin, OUTPUT);
pinMode(FiskalPulseSendNote, OUTPUT);
digitalWrite(FiskalPulseSendCoin, HIGH);
digitalWrite(FiskalPulseSendNote, HIGH);
digitalWrite(sendPin, HIGH);
void FiskCoin()
prev_time = millis();
attachInterrupt(digitalPinToInterrupt(interruptPin2), PulsTimeCoin, HIGH);
void PulsTimeCoin(){
attachInterrupt(digitalPinToInterrupt(interruptPin2), FiskCoin, LOW);
pwm_value = millis()-prev_time;
pwm_value = pwm_value ;
Serial.println (pwm_value);
if((pwm_value > 6) && (pwm_value < 13 ))
digitalWrite(FiskalPulseSendCoin,LOW );
delay(20);
digitalWrite(FiskalPulseSendCoin, HIGH );
Serial.print("Fiskalizirao kovanicu");
Serial.print('\n');
pwm_value = 0;
pwm_value = 0;
Serial.print("PREKRATAK ILI PREDUGACAK PULS");
Serial.print('\n');
void FiskNov() {
prev_time2 = millis();
attachInterrupt(digitalPinToInterrupt(interruptPin), PulsTimeNote, HIGH);
void PulsTimeNote() {
attachInterrupt(digitalPinToInterrupt(interruptPin), FiskNov, LOW);
digitalWrite(interruptPin, HIGH);
pwm_value2 = millis()-prev_time2;
pwm_value2 = pwm_value2 ;
Serial.println (abs(pwm_value2));
if((pwm_value2 > 45) && (pwm_value2 <65 ))
digitalWrite(sendPin, LOW);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
digitalWrite(ledPin, LOW);
Serial.print("proslijedio puls novčanice u aparat");
Serial.print('\n');
//-----------------fiskal novcanice
digitalWrite(FiskalPulseSendNote,LOW );
delay(2000);
digitalWrite(FiskalPulseSendNote,HIGH );
Serial.print("Fiskalizirao novčanicu");
Serial.print('\n');
pwm_value2 = 0;
Serial.print("PREDUG ILI PREKRATAK PULS ACCEPTOR");
Serial.print('\n');
haluzanpavao#1008
Postovi: 75
Re: digitalWrite() i delay u voidu od interrupta ne radi
Post Postao/la haluzanpavao#1008 » sri tra 07, 2021 1:06 pm
kAO PRVO NAREDBA ZA PVM = analogwrite(broj_pina.vrijednost_PWM);
A za vrijeme zabranjenog interupta ne radi niti delay ni pwm, jer su vezani na interupte koji su zabranjeni!!
Baci pogled na moje interupt rutine ovdije https://forum.e-radionica.com/hr/viewto ... f=15&t=326 redovi od 258-274
pozdrav
Pavel
Post Postao/la karlo.schweiger#8434 » sri tra 07, 2021 5:35 pm
ja sam teži početnik pa me zanima dali se može negdje uplatiti da mi to napišete ?
Sve radi osim slanja impulsa na pin 5 i 7
haluzanpavao#1008
Postovi: 75
Post Postao/la haluzanpavao#1008 » sri tra 07, 2021 9:28 pm
pokušaj ovako oblikovan kod
on radi, ali nemam hardvare da ga komplet isprobam
pažljivo si pročitaj ovaj link. https://www.arduino.cc/reference/en/lan ... interrupt/
I napomena "ovdije se niš ne plača a pogotovo ne meni."
Ako sam pomogao, biče mi drago :)
volatile int pwm_value2 = 0; //
volatile int prev_time2 = 0; //
//digitalWrite(interruptPin2, HIGH);
digitalWrite(FiskalPulseSendCoin, 1);
digitalWrite(FiskalPulseSendNote, 1);
digitalWrite(sendPin, 1);
void FiskCoin()
prev_time = micros();
//attachInterrupt(digitalPinToInterrupt(interruptPin2), PulsTimeCoin, HIGH);
//void PulsTimeCoin(){
//attachInterrupt(digitalPinToInterrupt(interruptPin2), FiskCoin, LOW);
pwm_value = micros()-prev_time;
digitalWrite(FiskalPulseSendCoin,0 );
delayMicroseconds(20000);
digitalWrite(FiskalPulseSendCoin, 1 );
Serial.println('\n');
pwm_value = 0;
pwm_value = 0;
//Serial.print('\n');
void FiskNov() {
prev_time2 = micros();
/* //proba vremena
long a=micros();
delayMicroseconds(2000000);
Serial.println(micros()-a);
//ovi redovi koje sam stavio pod remark nesmiju postojati
//attachInterrupt(digitalPinToInterrupt(interruptPin), PulsTimeNote, HIGH);
//void PulsTimeNote() {
//attachInterrupt(digitalPinToInterrupt(interruptPin), FiskNov, LOW);
//digitalWrite(interruptPin, HIGH); pin je pool up_an i netreba ga ručno dizati
pwm_value2 = micros()-prev_time2;
// pwm_value2 = pwm_value2 ;// nepotrebna naredba
if(((pwm_value2/1000) > 45) && ((pwm_value2/1000) <65 ))//Variabla sadrži microsekunde pa trreba broj podijeliti sa 1000
digitalWrite(sendPin, 0);
delayMicroseconds(10000);
digitalWrite(ledPin, 0);
Serial.println("proslijedio puls novčanice u aparat");
digitalWrite(FiskalPulseSendNote,0 );
digitalWrite(FiskalPulseSendNote,1 );
Serial.println("Fiskalizirao novčanicu");
pwm_value2 = 0;
Serial.println("PREDUG ILI PREKRATAK PULS ACCEPTOR");
robertperic#2201
Pridružen/a: pon ožu 08, 2021 12:31 pm
Post Postao/la robertperic#2201 » čet tra 08, 2021 9:10 am
Pozdrav, prvo digitalWrite neće raditi nakon što je pin postavljen kao INPUT_PULLUP.
zatim delayMicroseconds će raditi umjesto delay(), ali nije ga pametno koristiti unutar interrupta. Trebali bi razmisliti o implementaciji na drugi način ako će to biti veći projekt. Za manje stvari bi mogao raditi ok sa delayMicroseconds().
Ovaj post je jako dobro objasnio kako pravilno raditi sa intrerruptima:
https://roboticsbackend.com/arduino-interrupts/
