433MHz prijemnik ne ocitaje kod?
Pitanja vezana uz IoT (Internet of Things) te komunikacijske dijelove iz ponude e-radionica.com
ivan.marin2525#3510
Postovi: 4
Pridružen/a: sri sij 20, 2021 2:32 pm
Post Postao/la ivan.marin2525#3510 » pet sij 22, 2021 9:13 pm
Narucio sam ovaj predajnik i prijemnik: https://e-radionica.com/hr/433mhz-rf-od ... emnik.html
Medutim kad ga spojim (vcc, gnd i data na D11 ili D2, ovisno o kodu), ne dobijem nikakav rezultat u serial monitoru kad pritiskam tipke na 43MHz daljinskome. Radim li nesto krivo ili?
Da napomenem, imam ovakva dva identicna rf prijemnika i isti je rezultat na oba...
Kod1:
Example for receiving
https://github.com/sui77/rc-switch/
If you want to visualize a telegram copy the raw data and
paste it into http://test.sui.li/oszi/
#include <RCSwitch.h>
RCSwitch mySwitch = RCSwitch();
mySwitch.enableReceive(0); // Receiver on interrupt 0 => that is pin #2
if (mySwitch.available()) {
Serial.println("DATA: ");
output(mySwitch.getReceivedValue(), mySwitch.getReceivedBitlength(), mySwitch.getReceivedDelay(), mySwitch.getReceivedRawdata(),mySwitch.getReceivedProtocol());
mySwitch.resetAvailable();
Kod2:
#include "RH_ASK.h"
#ifdef RH_HAVE_HARDWARE_SPI
#include <SPI.h> // Not actually used but needed to compile
#endif // pin 11 for data
RH_ASK driver_rx; // kreiranje RH_ASK objekta
uint8_t buff[50]; // buffer
uint8_t bufflen = sizeof(buff); // veličina buffera u bajtovima
uint16_t value; // varijabla u kojoj će biti rekonstruirana vrijednost sa adc-a
Serial.begin(9600); // zapocni serijsku komunikaciju
if (!driver_rx.init()) { // ako receiver nije uspjesno inicijaliziran
Serial.println("init failed");
if (driver_rx.recv(buff, &bufflen)) {// Non-blocking
driver_rx.recv(buff, &bufflen);
int i;
// Message with a good checksum received, dump it.
driver_rx.printBuffer("Got:", buff, bufflen);
ivan.fadiga#3676
Postovi: 125
Re: 433MHz prijemnik ne ocitaje kod?
Post Postao/la ivan.fadiga#3676 » pon sij 25, 2021 7:10 am
Koristite li antenu na prijemniku?
Ako imate 2 mikrokontrolera trebalo bi isprobati rade li prijemnik i predajnik kako treba (na linku ima jednostavna tutorijal).
Daljinski šalje kodirani signal koji se treba na strani prijemnika dekodirati, pa se zbog toga javljaju problemi.
Ako uspijete pokrenuti primjer iz KKM-a da radi onda su moduli ispravni samo treba naći način kako raditi s daljinskim.
Svakako treba prvo jednostavne primjere namjestiti da rade, a kasnije s težima.
