Nakon nekog vremena ne korištenja pločice pokušao sam testni program uploadati na pločicu:
pinMode(13, OUTPUT);
digitalWrite(13, HIGH);
digitalWrite(13, LOW);
delay(5000);
Arduino: 1.8.5 (Linux), Board: "Croduino Basic2 PB"
/opt/arduino-1.8.5/arduino-builder -dump-prefs -logger=machine -hardware /opt/arduino-1.8.5/hardware -hardware /home/marin/.arduino15/packages -tools /opt/arduino-1.8.5/tools-builder -tools /opt/arduino-1.8.5/hardware/tools/avr -tools /home/marin/.arduino15/packages -built-in-libraries /opt/arduino-1.8.5/libraries -libraries /home/marin/Arduino/libraries -fqbn=e-radionica.com:avr:atmega328pbcc -ide-version=10805 -build-path /tmp/arduino_build_520688 -warnings=none -build-cache /tmp/arduino_cache_651168 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=/home/marin/.arduino15/packages/arduino/tools/arduinoOTA/1.2.0 -prefs=runtime.tools.avrdude.path=/home/marin/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14 -prefs=runtime.tools.avr-gcc.path=/home/marin/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -verbose /home/marin/Desktop/Blink/Blink.ino
/opt/arduino-1.8.5/arduino-builder -compile -logger=machine -hardware /opt/arduino-1.8.5/hardware -hardware /home/marin/.arduino15/packages -tools /opt/arduino-1.8.5/tools-builder -tools /opt/arduino-1.8.5/hardware/tools/avr -tools /home/marin/.arduino15/packages -built-in-libraries /opt/arduino-1.8.5/libraries -libraries /home/marin/Arduino/libraries -fqbn=e-radionica.com:avr:atmega328pbcc -ide-version=10805 -build-path /tmp/arduino_build_520688 -warnings=none -build-cache /tmp/arduino_cache_651168 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=/home/marin/.arduino15/packages/arduino/tools/arduinoOTA/1.2.0 -prefs=runtime.tools.avrdude.path=/home/marin/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14 -prefs=runtime.tools.avr-gcc.path=/home/marin/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -verbose /home/marin/Desktop/Blink/Blink.ino
Using board 'atmega328pbcc' from platform in folder: /home/marin/.arduino15/packages/e-radionica.com/hardware/avr/1.0.0
Using core 'arduino' from platform in folder: /home/marin/.arduino15/packages/arduino/hardware/avr/1.6.207
Build options changed, rebuilding all
Detecting libraries used...
"/home/marin/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-I/home/marin/.arduino15/packages/arduino/hardware/avr/1.6.207/cores/arduino" "-I/home/marin/.arduino15/packages/e-radionica.com/hardware/avr/1.0.0/variants/atmega328pb" "/tmp/arduino_build_520688/sketch/Blink.ino.cpp" -o "/dev/null"
Generating function prototypes...
"/home/marin/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-I/home/marin/.arduino15/packages/arduino/hardware/avr/1.6.207/cores/arduino" "-I/home/marin/.arduino15/packages/e-radionica.com/hardware/avr/1.0.0/variants/atmega328pb" "/tmp/arduino_build_520688/sketch/Blink.ino.cpp" -o "/tmp/arduino_build_520688/preproc/ctags_target_for_gcc_minus_e.cpp"
"/opt/arduino-1.8.5/tools-builder/ctags/5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "/tmp/arduino_build_520688/preproc/ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"/home/marin/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-I/home/marin/.arduino15/packages/arduino/hardware/avr/1.6.207/cores/arduino" "-I/home/marin/.arduino15/packages/e-radionica.com/hardware/avr/1.0.0/variants/atmega328pb" "/tmp/arduino_build_520688/sketch/Blink.ino.cpp" -o "/tmp/arduino_build_520688/sketch/Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core
Linking everything together...
"/home/marin/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc" -w -Os -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328pb -o "/tmp/arduino_build_520688/Blink.ino.elf" "/tmp/arduino_build_520688/sketch/Blink.ino.cpp.o" "/tmp/arduino_build_520688/../arduino_cache_651168/core/core_e-radionica.com_avr_atmega328pbcc_49bdd6895a46da3b0c2d3d4885fc7a64.a" "-L/tmp/arduino_build_520688" -lm
"/home/marin/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "/tmp/arduino_build_520688/Blink.ino.elf" "/tmp/arduino_build_520688/Blink.ino.eep"
"/home/marin/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-objcopy" -O ihex -R .eeprom "/tmp/arduino_build_520688/Blink.ino.elf" "/tmp/arduino_build_520688/Blink.ino.hex"
Sketch uses 1280 bytes (3%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
/home/marin/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/bin/avrdude -C/home/marin/.arduino15/packages/e-radionica.com/hardware/avr/1.0.0/tools/avrdude.conf -v -patmega328pb -carduino -P/dev/ttyUSB0 -b57600 -D -Uflash:w:/tmp/arduino_build_520688/Blink.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/home/marin/.arduino15/packages/e-radionica.com/hardware/avr/1.0.0/tools/avrdude.conf"
User configuration file is "/home/marin/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyUSB0
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xe0
avrdude done. Thank you.
An error occurred while uploading the sketch
Kada pritisnem reset tipku na pločici ništa se ne događa. Molim Vas za pomoć.
Lijep pozdrav,
Marin
