Problem sa uploadovanjem SGP 30 koda na Croduino Basic 3
Pitanja vezana uz Croduino pločice: Basic serija, NOVA/miniNOVA serija, STM32, Damba itd.
advancedgwt#6492
Postovi: 132
Post Postao/la advancedgwt#6492 » pon tra 01, 2019 7:26 pm
Moram prvo reci da sam pre Croduino BASIC 3 imao podesen Arduino IDE za Croduino NOVA 2 i sve je radilo OK. Uputstvo za Croduino BASIC 3 je jednostavno, prvo se instalira drajver CH i pokaze se da je na COM 5 (sto je najveci com), podesen je Arudino Nano i dobijam ovo kada zelim uploadovati kod
Arduino: 1.8.5 (Windows 10), Board: "Arduino Nano, ATmega328P"
Sketch uses 4776 bytes (15%) of program storage space. Maximum is 30720 bytes.
Global variables use 409 bytes (19%) of dynamic memory, leaving 1639 bytes for local variables. Maximum is 2048 bytes.
An error occurred while uploading the sketch
Invalid library found in C:\Program Files (x86)\Arduino\libraries\sketch_jul06a: C:\Program Files (x86)\Arduino\libraries\sketch_jul06a
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
david.zovko#9766
Postovi: 438
Re: Problem sa uploadovanjem SGP 30 koda na Croduino Basic 3
Post Postao/la david.zovko#9766 » pon tra 01, 2019 8:30 pm
ovo je nekakava greška s kodom, ne brini, nema veze s pločicom.
Molim te obriši folder C:\Program Files (x86)\Arduino\libraries\sketch_jul06a i pokušaj ponovno
advancedgwt#6492
Postovi: 132
Post Postao/la advancedgwt#6492 » uto tra 02, 2019 1:24 pm
Ok, hvala :)
advancedgwt#6492
Postovi: 132
Post Postao/la advancedgwt#6492 » uto tra 02, 2019 10:16 pm
Obrisao i dobio ovo
david.zovko#9766
Postovi: 438
Post Postao/la david.zovko#9766 » sri tra 03, 2019 10:26 pm
Fali mi malo detalja. Daj molim te enableaj taj Show verbose output during compilation u postavkama pa kopiraj cijeli error
advancedgwt#6492
Postovi: 132
Post Postao/la advancedgwt#6492 » pet tra 05, 2019 9:06 pm
Ok
hrvoje.penavin#5931
Postovi: 11
Lokacija: Sisak
Post Postao/la hrvoje.penavin#5931 » ned tra 07, 2019 1:08 pm
Imam također, pločicu Croduino 3 Basic. S postavkama kao na priloženoj slici radi kako treba.
Probaj s programom "Blink" radi li. Ako radi moguće je da u tvom programu imaš nešto neusklađeno.
Lijepi pozdrav!
advancedgwt#6492
Postovi: 132
Post Postao/la advancedgwt#6492 » ned svi 12, 2019 3:29 pm
Sa malim zakasnjenjem, sve isto kao kod tebe.
hrvoje.penavin#7698 je napisao/la:
advancedgwt#6492
Postovi: 132
Post Postao/la advancedgwt#6492 » ned svi 12, 2019 3:32 pm
Davide, sa zakasnjenjem, ukljucio sam verbose i evo teksta
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\dkaludjerovic\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\dkaludjerovic\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\dkaludjerovic\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10805 -build-path C:\Users\DKALUD~1\AppData\Local\Temp\arduino_build_144511 -warnings=none -build-cache C:\Users\DKALUD~1\AppData\Local\Temp\arduino_cache_985908 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.0 -prefs=runtime.tools.avrdude.path=C:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14 -prefs=runtime.tools.avr-gcc.path=C:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2 -verbose C:\Users\dkaludjerovic\Documents\Arduino\SGP_30\SGP_30.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\dkaludjerovic\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\dkaludjerovic\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\dkaludjerovic\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10805 -build-path C:\Users\DKALUD~1\AppData\Local\Temp\arduino_build_144511 -warnings=none -build-cache C:\Users\DKALUD~1\AppData\Local\Temp\arduino_cache_985908 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.0 -prefs=runtime.tools.avrdude.path=C:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14 -prefs=runtime.tools.avr-gcc.path=C:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2 -verbose C:\Users\dkaludjerovic\Documents\Arduino\SGP_30\SGP_30.ino
Using board 'nano' from platform in folder: C:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.207
Using core 'arduino' from platform in folder: C:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.207
Detecting libraries used...
"C:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.207\cores\arduino" "-IC:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.207\variants\eightanaloginputs" "C:\Users\DKALUD~1\AppData\Local\Temp\arduino_build_144511\sketch\SGP_30.ino.cpp" -o "nul"
"C:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.207\cores\arduino" "-IC:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.207\variants\eightanaloginputs" "-IC:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.207\libraries\Wire\src" "C:\Users\DKALUD~1\AppData\Local\Temp\arduino_build_144511\sketch\SGP_30.ino.cpp" -o "nul"
"C:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.207\cores\arduino" "-IC:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.207\variants\eightanaloginputs" "-IC:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.207\libraries\Wire\src" "-IC:\Users\dkaludjerovic\Documents\Arduino\libraries\Adafruit_SGP30-master" "C:\Users\DKALUD~1\AppData\Local\Temp\arduino_build_144511\sketch\SGP_30.ino.cpp" -o "nul"
Using cached library dependencies for file: C:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.207\libraries\Wire\src\Wire.cpp
Using cached library dependencies for file: C:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.207\libraries\Wire\src\utility\twi.c
Using cached library dependencies for file: C:\Users\dkaludjerovic\Documents\Arduino\libraries\Adafruit_SGP30-master\Adafruit_SGP30.cpp
Generating function prototypes...
"C:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.207\cores\arduino" "-IC:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.207\variants\eightanaloginputs" "-IC:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.207\libraries\Wire\src" "-IC:\Users\dkaludjerovic\Documents\Arduino\libraries\Adafruit_SGP30-master" "C:\Users\DKALUD~1\AppData\Local\Temp\arduino_build_144511\sketch\SGP_30.ino.cpp" -o "C:\Users\DKALUD~1\AppData\Local\Temp\arduino_build_144511\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\DKALUD~1\AppData\Local\Temp\arduino_build_144511\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.207\cores\arduino" "-IC:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.207\variants\eightanaloginputs" "-IC:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.207\libraries\Wire\src" "-IC:\Users\dkaludjerovic\Documents\Arduino\libraries\Adafruit_SGP30-master" "C:\Users\DKALUD~1\AppData\Local\Temp\arduino_build_144511\sketch\SGP_30.ino.cpp" -o "C:\Users\DKALUD~1\AppData\Local\Temp\arduino_build_144511\sketch\SGP_30.ino.cpp.o"
Compiling libraries...
Compiling library "Wire"
Using previously compiled file: C:\Users\DKALUD~1\AppData\Local\Temp\arduino_build_144511\libraries\Wire\Wire.cpp.o
Using previously compiled file: C:\Users\DKALUD~1\AppData\Local\Temp\arduino_build_144511\libraries\Wire\utility\twi.c.o
Compiling library "Adafruit_SGP30-master"
Using previously compiled file: C:\Users\DKALUD~1\AppData\Local\Temp\arduino_build_144511\libraries\Adafruit_SGP30-master\Adafruit_SGP30.cpp.o
Compiling core...
Using precompiled core
Linking everything together...
"C:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p  -o "C:\Users\DKALUD~1\AppData\Local\Temp\arduino_build_144511/SGP_30.ino.elf" "C:\Users\DKALUD~1\AppData\Local\Temp\arduino_build_144511\sketch\SGP_30.ino.cpp.o" "C:\Users\DKALUD~1\AppData\Local\Temp\arduino_build_144511\libraries\Wire\Wire.cpp.o" "C:\Users\DKALUD~1\AppData\Local\Temp\arduino_build_144511\libraries\Wire\utility\twi.c.o" "C:\Users\DKALUD~1\AppData\Local\Temp\arduino_build_144511\libraries\Adafruit_SGP30-master\Adafruit_SGP30.cpp.o" "C:\Users\DKALUD~1\AppData\Local\Temp\arduino_build_144511/..\arduino_cache_985908\core\core_arduino_avr_nano_cpu_atmega328_71389980eafe11a1aa816f101e06896c.a" "-LC:\Users\DKALUD~1\AppData\Local\Temp\arduino_build_144511" -lm
"C:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0  "C:\Users\DKALUD~1\AppData\Local\Temp\arduino_build_144511/SGP_30.ino.elf" "C:\Users\DKALUD~1\AppData\Local\Temp\arduino_build_144511/SGP_30.ino.eep"
"C:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2/bin/avr-objcopy" -O ihex -R .eeprom  "C:\Users\DKALUD~1\AppData\Local\Temp\arduino_build_144511/SGP_30.ino.elf" "C:\Users\DKALUD~1\AppData\Local\Temp\arduino_build_144511/SGP_30.ino.hex"
Using library Wire at version 1.0 in folder: C:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.207\libraries\Wire
Using library Adafruit_SGP30-master at version 1.0.3 in folder: C:\Users\dkaludjerovic\Documents\Arduino\libraries\Adafruit_SGP30-master
C:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14/bin/avrdude -CC:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b115200 -D -Uflash:w:C:\Users\DKALUD~1\AppData\Local\Temp\arduino_build_144511/SGP_30.ino.hex:i
avrdude: Version 6.3-20171130
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\dkaludjerovic\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14/etc/avrdude.conf"
         Using Port                    : COM5
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x3a
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x3a
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x3a
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x3a
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x3a
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x3a
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x3a
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x3a
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x3a
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x3a
avrdude done.  Thank you.
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
david.zovko#9766
Postovi: 438
Post Postao/la david.zovko#9766 » ned svi 12, 2019 11:12 pm
Sve izgleda u redu s postavakama Arduino IDE i compile-om.
Daj molim te da provjerimo taj port, jel ti se u Device Manager prikazuje port kao na ovoj slici: https://e-radionica.com/hr/blog/2018/11 ... /#“windows
advancedgwt#6492
Postovi: 132
Post Postao/la advancedgwt#6492 » uto lip 04, 2019 10:26 pm
Davide, ispirka za late reply, da ovo je bio problem, CH nema u device driveru.
Sto da radim?
ivan.fadiga#3643
Postovi: 157
Post Postao/la ivan.fadiga#3643 » sri lip 05, 2019 10:43 am
Imate ovdje upute za instalaciju pa probajte tako napraviti.
https://e-radionica.com/hr/blog/2018/11 ... ic3-nova2/
advancedgwt#6492
Postovi: 132
Post Postao/la advancedgwt#6492 » pon srp 08, 2019 7:40 pm
Reseno, hvala.
