Problem Croduino Basic2 PB
marin.mihajlovic1994#5748
Post Postao/la marin.mihajlovic1994#5748 » pon stu 12, 2018 9:02 am
Nakon nekog vremena ne korištenja pločice pokušao sam testni program uploadati na pločicu:
  pinMode(13, OUTPUT);
  digitalWrite(13, HIGH);
  digitalWrite(13, LOW);
  delay(5000);
ali prilikom uploada mi se javlja greška:
Arduino: 1.8.5 (Linux), Board: "Croduino Basic2 PB"
/opt/arduino-1.8.5/arduino-builder -dump-prefs -logger=machine -hardware /opt/arduino-1.8.5/hardware -hardware /home/marin/.arduino15/packages -tools /opt/arduino-1.8.5/tools-builder -tools /opt/arduino-1.8.5/hardware/tools/avr -tools /home/marin/.arduino15/packages -built-in-libraries /opt/arduino-1.8.5/libraries -libraries /home/marin/Arduino/libraries -fqbn=e-radionica.com:avr:atmega328pbcc -ide-version=10805 -build-path /tmp/arduino_build_520688 -warnings=none -build-cache /tmp/arduino_cache_651168 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=/home/marin/.arduino15/packages/arduino/tools/arduinoOTA/1.2.0 -prefs=runtime.tools.avrdude.path=/home/marin/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14 -prefs=runtime.tools.avr-gcc.path=/home/marin/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -verbose /home/marin/Desktop/Blink/Blink.ino
/opt/arduino-1.8.5/arduino-builder -compile -logger=machine -hardware /opt/arduino-1.8.5/hardware -hardware /home/marin/.arduino15/packages -tools /opt/arduino-1.8.5/tools-builder -tools /opt/arduino-1.8.5/hardware/tools/avr -tools /home/marin/.arduino15/packages -built-in-libraries /opt/arduino-1.8.5/libraries -libraries /home/marin/Arduino/libraries -fqbn=e-radionica.com:avr:atmega328pbcc -ide-version=10805 -build-path /tmp/arduino_build_520688 -warnings=none -build-cache /tmp/arduino_cache_651168 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=/home/marin/.arduino15/packages/arduino/tools/arduinoOTA/1.2.0 -prefs=runtime.tools.avrdude.path=/home/marin/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14 -prefs=runtime.tools.avr-gcc.path=/home/marin/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -verbose /home/marin/Desktop/Blink/Blink.ino
Using board 'atmega328pbcc' from platform in folder: /home/marin/.arduino15/packages/e-radionica.com/hardware/avr/1.0.0
Using core 'arduino' from platform in folder: /home/marin/.arduino15/packages/arduino/hardware/avr/1.6.207
Build options changed, rebuilding all
Detecting libraries used...
"/home/marin/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-I/home/marin/.arduino15/packages/arduino/hardware/avr/1.6.207/cores/arduino" "-I/home/marin/.arduino15/packages/e-radionica.com/hardware/avr/1.0.0/variants/atmega328pb" "/tmp/arduino_build_520688/sketch/Blink.ino.cpp" -o "/dev/null"
Generating function prototypes...
"/home/marin/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-I/home/marin/.arduino15/packages/arduino/hardware/avr/1.6.207/cores/arduino" "-I/home/marin/.arduino15/packages/e-radionica.com/hardware/avr/1.0.0/variants/atmega328pb" "/tmp/arduino_build_520688/sketch/Blink.ino.cpp" -o "/tmp/arduino_build_520688/preproc/ctags_target_for_gcc_minus_e.cpp"
"/opt/arduino-1.8.5/tools-builder/ctags/5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "/tmp/arduino_build_520688/preproc/ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"/home/marin/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-I/home/marin/.arduino15/packages/arduino/hardware/avr/1.6.207/cores/arduino" "-I/home/marin/.arduino15/packages/e-radionica.com/hardware/avr/1.0.0/variants/atmega328pb" "/tmp/arduino_build_520688/sketch/Blink.ino.cpp" -o "/tmp/arduino_build_520688/sketch/Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core
Linking everything together...
"/home/marin/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc" -w -Os -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328pb  -o "/tmp/arduino_build_520688/Blink.ino.elf" "/tmp/arduino_build_520688/sketch/Blink.ino.cpp.o" "/tmp/arduino_build_520688/../arduino_cache_651168/core/core_e-radionica.com_avr_atmega328pbcc_49bdd6895a46da3b0c2d3d4885fc7a64.a" "-L/tmp/arduino_build_520688" -lm
"/home/marin/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0  "/tmp/arduino_build_520688/Blink.ino.elf" "/tmp/arduino_build_520688/Blink.ino.eep"
"/home/marin/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-objcopy" -O ihex -R .eeprom  "/tmp/arduino_build_520688/Blink.ino.elf" "/tmp/arduino_build_520688/Blink.ino.hex"
Sketch uses 1280 bytes (3%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
/home/marin/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/bin/avrdude -C/home/marin/.arduino15/packages/e-radionica.com/hardware/avr/1.0.0/tools/avrdude.conf -v -patmega328pb -carduino -P/dev/ttyUSB0 -b57600 -D -Uflash:w:/tmp/arduino_build_520688/Blink.ino.hex:i
avrdude: Version 6.3-20171130
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/home/marin/.arduino15/packages/e-radionica.com/hardware/avr/1.0.0/tools/avrdude.conf"
         User configuration file is "/home/marin/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/ttyUSB0
         Using Programmer              : arduino
         Overriding Baud Rate          : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xe0
avrdude done.  Thank you.
An error occurred while uploading the sketch
Pod tools -> board postavljena je Croduino Basic2 PB.
Kada pritisnem reset tipku na pločici ništa se ne događa. Molim Vas za pomoć.
Lijep pozdrav,
Marin
david.zovko#2434
Postovi: 436
Re: Problem Croduino Basic2 PB
Post Postao/la david.zovko#2434 » sri stu 14, 2018 2:29 pm
molim Vas screenshot Tools izbornika iz Arduino IDE
j.radic996#3004
Post Postao/la j.radic996#3004 » čet ožu 28, 2019 6:00 pm
Prije godinu dana sam kupila croduino i bilo je sve okej sa projektom kojeg sam radila. Od tada ga nisam koristila sada i sada kad ga opet koristim išla sam napravit blink test da vidim jesam li ispravno instalirala i nakon kompajliranja javi mi se sljedeća greška:
Znate li možda u čemu je problem?
Hvala :)
ivan.fadiga#2311
Postovi: 153
Post Postao/la ivan.fadiga#2311 » čet ožu 28, 2019 8:23 pm
Nisam radio sa tim Croduinom, ali dali ste u Arduino IDE dodali Croduino Basic2 PB te ga odabrali za pločicu pod Tools>Board?
dekip#8523
Postovi: 88
Post Postao/la dekip#8523 » pet ožu 29, 2019 10:15 pm
Mislim da i ti imaš problem sa odabranom pločom. Za ploču izaberi Arduino Nano (old bootloader).
Ovo ako govorimo o Basic2.
david.zovko#2434
Postovi: 436
Post Postao/la david.zovko#2434 » sub ožu 30, 2019 1:54 pm
Molim te posjeti ovu stranicu: https://e-radionica.com/hr/arduino-ide
Odaberi svoju pločicu i slijedi upute za postavljanje Arduino IDE-a. Ako i dalje bude problema, javi :)
j.radic996#3004
Post Postao/la j.radic996#3004 » pon tra 01, 2019 8:13 pm
Evo ponovo sam sve instalirala kako piše na stranici, opet mi se javlja error.
Na starom laptopu sve radi normalno, pa pretpostavljam da nešto krivo radim ali stvarno ne znam šta. :clap: :dance:
Hvala vam svima puno,
Jelena
david.zovko#2434
Postovi: 436
Post Postao/la david.zovko#2434 » pon tra 01, 2019 8:27 pm
ako pločica radi na drugom laptopu onda je ispravna, samo je negdje greška u postavkama. Pronać ćemo ju :)
Možeš li molim te napraviti dvije stvari:
1. Odi na Tools -> Board -> Board Manager. U search upiši "avr". Postoji li na prvoj stavci, "Arduino AVR boards", opcija za update? Ako da, molim te updejtaj. Ugasi/upali Arduino IDE i probaj ponovno.
2. Postavi screenshot Tools izbornika.
j.radic996#3004
Post Postao/la j.radic996#3004 » sri tra 03, 2019 4:48 pm
Evo da se javim, nakon dana pronalaženja problema, našla sam sve. Problem je bio u ć slovu u mom prezimenu kojeg sam stavila za username na početku instaliranja windowsa kojeg arduino nije moga procitat... :dance:
Hvala vam svima, i pardon na smetnji i gnjavaži 8-)
david.zovko#2434
Postovi: 436
Post Postao/la david.zovko#2434 » sri tra 03, 2019 10:27 pm
Svašta! :? ali čestitam na uspjehu i hvala što javljaš što je bio problem, tako da i drugima pomogneš kada dođu do istog problema!
